Originally Posted by mike newall
I'm biaised, the tailwheel versions look nicer, don't have any vices, have less dangling both outside and under the hood and would always be my preferred choice. Less of a step to get into as well.
In the air - no difference, going in and out of unpaved strips - tail wheel every time.
And I still think the nose wheel versions of the 6,7, and 9 look better on the ground. Just more substantial I suppose
I'd go for the tailwheel "8" over the nose version, but much prefer aircraft such as Aviat Husky's for rough field work. I just don't believe that taildragging RV's with tight fitting wheel pants to cut drag for gains in speed are any "real" sort of rough field airplanes.
For all those abandoned mining strips etc, throughout Idaho, Utah, Wyoming, and Montana; I want no wheelpants and much larger diameter tires than I find on RV's. Just being realistic here.
L.Adamson RV6A
