VM1000 ammeter/amps transducer problem
Hey Guys,
Have any of you experienced any problem with your amps reading with the Vision Microsystems VM1000C. My amps are fluctuating wildly but slowly and does not seem to be accurate. It was fine for approximately 100 hrs and in the last 30 it seems to be giving innacurate readings. Yesterday was the worst, fluctuating from -5 to +30. None of the items that are operating seem to be affected so that's why I think it must be an indicator/transducer problem. The VMS uses a little hall effect transducer.
Thank you,
Jerry
