Old 08-19-2007, 11:40 AM
Brambo Brambo is offline
Question Throttle & Mixture Cables
I started looking at how I'm going to install the throttle and mixture cables. There are two small nuts near the end of the cable (to attach to a bracket on the engine) and one large nut (to attach to the instrument panel). What is the trick to getting all the nuts off to install the cable? The big nut won't slide over the small ones, and the small ones won't slide over the rubber cover. What's the trick?
Bill Rambo
RV-7A
Old 08-19-2007, 11:57 AM
gasman gasman is offline
This is a question that your DAR might ask of you to see if you did build your project.
Old 08-19-2007, 12:13 PM
Build9A's Avatar
Build9A Build9A is offline
Default pull the rubber covers off
All the nuts and rubber covers will come off and go back on. If I remember correctly, remove the rubber covers first. take care.
RV9A N489JE - Flying
Eagle Neck Airpark
Shellmans Bluff, Georgia
Old 08-19-2007, 04:10 PM
Thanks, I thought that might be the case. I just didn't want to start pulling off rubber covers without at least asking first
Bill Rambo
RV-7A
