Phil,
I experimented with using the fuel tank dies from Cleaveland on the inside dimples and the standard die on the skin, it looked the same, seemed to fit pretty much the same so I just stuck with the standard dies for both surfaces. The tank die is a tad bigger to allow for the rivet to sit flush when using proseal. I used them on the tanks and all the rivets sit flush.
I don't know if it made a difference because I didn't use anything but the tank dies on the tank. I suggest making a few test strips out of different thickness of aluminum. Dimple the strips with each size. You can see how well the skins will fit plus use it to test your microstop for the correct depth. Sneak up on the correct size on scrap and make your countersinks fit your dimples perfectly without experimenting on the real thing.
Rick Sked
