Old 05-08-2022, 09:43 AM
Default 4-40 Countersink size?
What size countersink cutter for the 4-40 screw callout in Section 42 page 1?
I don't seem to see it listed on the Van's RV-12is list of recommended tools.
And thank you.
Bob Collins
St. Paul, MN.
Beginning RV-12iS avionics
Last article: "Gonna Finish This Sucker" (Kitplanes)
Old 05-08-2022, 09:52 AM
jask jask is offline
Default countersink
The size of the countersink does not matter, use whatever fits. What does matter is the degree. You can get them in 82, 90, and 100 degree. Aviation uses mostly 100 degree hardware.
And thank you.
RV-7 builder Ramona, CA.
Free prop balancing for Vanís owners.
RV-6A N665CM
Old 05-08-2022, 02:48 PM
Any idea what the angle is on a 4-40 screw?
Bob Collins
St. Paul, MN.
Old 05-08-2022, 03:15 PM
erich weaver's Avatar
If the screws originated from an aviation supply place, they will be 100 degree countersinks. Practice using your micro stop countersink on some scrap until you get the depth setting dialed in
Erich
RV-7A
Santa Ynez, CA
Old 05-08-2022, 03:17 PM
Default screws
4-40 is available in 82 or 100 deg
RV-6A N665CM
Old 05-08-2022, 04:48 PM
terrye terrye is offline
AN507 or MS24693 screws are 100* head angle. The "D" dimension of the head diameter to the sharp points is .207/.225".
Terry Edwards
RV-9A (Fuselage)
2021/2022 VAF Contribution Sent
Old 05-12-2022, 10:13 AM
madmax4499 madmax4499 is offline
I just used my 100 degree deburr tool. It only holds the Maint port and its under the shelf.
Old 05-12-2022, 07:09 PM
Just to follow up, a 4-40 takes a #43 bit for the hole so there's nothing that will fit in a microstop countersink cage as far I could find online for countersink cutters. I guess enlarging the hole to a #40 is the only way to do this.
Bob Collins
St. Paul, MN.
