Old 08-15-2007, 03:53 PM
FrankK90989 FrankK90989 is offline
Default Roll your own visors
Here is a pic of a pair of visors I cooked up, mounted them using the existing hole in the rollbar.
They will adjust back almost 180 deg.
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
Old 08-15-2007, 05:34 PM
mburch's Avatar
mburch mburch is offline
Frank,
That is awesome. How 'bout more pics / details? What material did you use? Do they block your view when they're stowed? Do they bang against the windscreen glass from vibration? Can they be removed easily? Inquiring minds want to know!
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 08-15-2007, 07:37 PM
FredMagare FredMagare is offline
I, for one, would lake a more detailed "how to" right-up, if you're in the mood, please.
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
RV-9A Firewall Forward
[Engine purchased]
Old 08-16-2007, 12:56 PM
Default Ok
Folks,
The acrylic is 4 1/4" X 10" dark smoke, screwed to a stiff aluminum 1/4" rod with 4-40 screws (drilled and tapped). the mount is all stainless .072 X .75 with a 1/4" socket for the rod TIG welded and tapped for a 8-32 knob.The distance between the socket and the bolt hole is 3/4" oc.
They vibrate very little and are breeze to remove. hope this helps
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
Old 08-18-2007, 09:39 AM
TravisHamblen's Avatar
TravisHamblen TravisHamblen is offline
Default Very nice!
So how much are you going to sell them for??? Seriuosly... You can mark me down for a set. I bet you could sell a couple hundred!
Travis
Old 08-18-2007, 09:47 PM
BruceP BruceP is offline
Yup, I'll take a pair too!
Bruce Peters
Bakersfield, CA
RV-9A, Flying 11/21/15
VAF#1145
Donation up to date 08/20
Old 11-12-2007, 08:03 AM
MrNomad's Avatar
MrNomad MrNomad is offline
Default GOOD JOB!!
Me too. I've been thinking of ways to do this. You just ended another sleepless nite.
Barry
Tucson
Old 01-07-2008, 07:34 AM
bsacks05's Avatar
bsacks05 bsacks05 is offline
Frank,
After last night's flight I got to thinking that I would really like to install some sort of visors in my -9. Your design looks simple and effective. My question is, now that you have been flying with them for a while, what changes/improvements would you make to the design, if any?
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 01-07-2008, 03:21 PM
Originally Posted by bsacks05 View Post
Frank,
I should anodize the rod some cool color (lazy). and add a inch to the depth to 5.5" .If it didn't work just cut it off. I do like them cause I don't wear shades they make my Dynons and pda gps hard to see.
I will send the Dynons in for the bright screen upgrade next month.
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
Old 01-08-2008, 06:48 AM
Steve Steve is offline
Default pix?
Frank,
If you get a chance, would you post a close up photo of the mount/pivot bracket? Good idea and clean installation.
Steve
