Height varies
You want enough that a nice seal is formed when the cowl pressure pushes the baffle material against the cowl. Typically, you need enough to close the gap, plus about an inch and a half for the "seal".
I just used safety wire to lace the corners together. Put the twists UNDER the seal so they do not contact your cowl and rub a hole in it.
Just MHO, YMMV, etc
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
