Old 08-14-2007, 10:33 AM
dustman dustman is offline
Default nav antenna
I am considering instaling a wing tip antenna would apreciate any comments pro or con for doing so thanks.
Old 08-14-2007, 11:30 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I've had great results from a homebuilt "Archer" clone in my right wingtip - works great for Nav. I have a similar one in the left tip for my #2 Comm, and it's fine for ranges up to 40-50 miles, but not much beyond that.
Search the Forums for "Archer", and you'll probably find a number of threads with comments, both positive and negative.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-14-2007, 11:38 AM
db1yg's Avatar
db1yg db1yg is offline
Ditto here on the wing tip Bob Archer nav antenna. I have one in the left wing tip of my 9a and it works great for nav and loc/gs. I installed a splitter on the line to feed the seperate inputs for the nav and loc/gs on my 430.
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
Old 08-15-2007, 09:30 AM
kentb's Avatar
kentb kentb is offline
Default Do the Nav, but not the com.
Nav antenna works great. The com antenna has less then haft the range as the bent whip on my belly.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 08-15-2007, 09:45 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Picture...
This might help for a DIY version...
http://home.hiwaay.net/~sbuc/tvrvbg/antenna.gif
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-15-2007, 08:54 PM
Default com antennas
Another question from a rank amaturer do i need 2 ant for my radio since it has flip flop capability.
Old 08-15-2007, 10:07 PM
az_gila's Avatar
Exclamation No...
No.. one comm antenna per comm radio....
gil A
Gil Alexander
Old 08-16-2007, 03:18 PM
jbDC9 jbDC9 is offline
For my wingtip nav antenna I used the el cheapo one ($27) from Vans... works pretty well as far as I can tell. From 6-7000 ft I can receive VORs up to maybe 80 or 90 miles away... good enough for me. The kit is as simple as it gets, just a strip of copper maybe 36 in. long, plus a length of antenna cable and a BNC connector. Just solder the connector to the strip, then bond the strip to the inside of the wingtip. Easy!
John Bixby
RV-8 QB sn 82030 - 1750 hrs
O-360-A1D/CS/Pmags
Houston, TX
Old 04-07-2008, 02:52 PM
Rivethead Rivethead is offline
Today I'm trying to figure out my antenna needs and am seriously giving thought to the Bob Archer antenna. I'm opening this thread back up because it is so far the only place I've read referance to being a g/s antenna. So how about it, IS the Bob Archer antenna usable as a g/s?
Old 04-07-2008, 03:08 PM
AltonD's Avatar
AltonD AltonD is offline
Jim, my understanding is that we can puta di/triplexor on the feed line and do just that. I have bought the archer Nav antenna, but not installed it yet. From what I have read, it has good results.
http://www.aircraftspruce.com/catalo..._couplers3.php
I think this is what Mr Dan is using.
Here is a good thread that is recent with Steinair comments:
http://www.vansairforce.com/communit...ight=triplexer
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
