Old 06-18-2005, 10:51 PM
fehdxl fehdxl is offline
Question aileron hinge bolt/nut
Please correct me if I'm wrong, but the picture below depicts a less than desirable technique of mounting the aileron to the wing....right?
A cotter pinned castle nut with the next size smaller bolt would be ideal, right?
Thank you for your time!
-Jim
P.S. Sorry for the low picture resolution.
Old 06-19-2005, 01:25 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Jim,
.... that is acceptable as long as the bolt is tightened against the inner ball (or race) of a bearing.
That is what is happening in this particular spot - and many other RV locations.
The bolt is not the pivot point, if it was, then the castle nut and cotter pin would be required.
It's OK...
gil in Tucson - EAA Technical Counselor
Old 06-19-2005, 08:34 AM
Default thanks!
Ahhh, now I understand. Thanks!
-Jim
