Old 08-12-2007, 12:34 PM
prkaye prkaye is offline
Default prime firewall parts?
Is it OK to prime the aluminum parts on the firewall.. stiffeners and gussets? Or will the heat from the engine compartment cook the primer off these?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 08-12-2007, 12:38 PM
Mel's Avatar
Mel Mel is offline
Priming firewall parts is fine. If it gets hot enough to "cook" the primer, then you have much bigger problems.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-12-2007, 07:32 PM
Captain_John's Avatar
I am priming most of my aircraft but for most of the interior cabin, I am going "Al Fresco"!
The way I see it, if the plane is flown regularly, (my personal objective) the cockpit should get ventilated often thereby eliminating the humidity from the environment. This means corrosion has no opportunity to form.
For this reason, I am cutting back on priming the interior cockpit area. Not entirely, just cutting back.
Case in point, I didn't prime those aforementioned stiffeners.
Does that help?
CJ
The experiment works!
