Old 08-09-2007, 11:17 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Skin Storage Question
I just inventoried my tail kit. Since I will be moving slow on this project at first, I need to store things in the garage. My question is the skins, what is the best way to store them for say a few months? Can I put them back in the box they were shipped in or should they be stored some other fashion? The other items I have shelf space for, and the rivet, nuts, bolts etc are arranged in tackle type boxes. I should also point out that my garage is somewhat climate controlled. It is a basement garage, and the ducting for the house runs throughout the garage ceiling. Consequently the temperature stays with in about 10 degrees of what the house is, that is if I don't forget and leave the door open. Thanks in advance for any advice.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 08-10-2007, 06:25 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Sounds to me like "the box they came in" would be excellent if you have the room to do that. My work bench was just the right size so that the empennage box fit underneath it, and was a good place to store those kind of things for a year or more.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-10-2007, 07:45 AM
DaX's Avatar
DaX DaX is offline
I left my skins in the box they came in and put them on a shelf - look in this picture above and to the left of the VS - that's the skins in the box:
http://flyingtodhunter.livejournal.com
RV-7 Wings, Tail, & Tools FOR SALE
Old 08-10-2007, 09:48 AM
RVG8tor's Avatar
Default Thanks on Skin Question
Thanks for the input. I was not sure about storage in the box, since Van's instructions say to unpack everything from the packing paper due to its ability to absorb moisture. I was not sure the cardboard box would be good for the skins. I too have a bench that the box should fit under.
It is all I can do not to work on this thing with every free moment, but I have a bathroom remodel to do first.
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 08-10-2007, 04:22 PM
TerryWighs TerryWighs is offline
Default Skin storage/basement
If your basement is similar to most...you may want to consider running a de-humidifier for air quality. Most basements are on the damp side, and these inexpensive units really help dry up the air...
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
