forward center baffles plate nuts?
EdRv7
Member
I'm trying to figure out how to rivet the center baffle brackets to the baffle floors. The problem is I have already installed the prop and spinner, so there is no room to rivet the center baffle/bracket/baffle floor together in place. I suppose I could take the propeller back off. Or has anybody used plate nuts under the baffle floor to fasten the forward baffle brackets?
