Old 01-19-2022, 12:36 PM
Steve Crewdog's Avatar
Steve Crewdog Steve Crewdog is offline
Default Dissimilar metal corrosion: avionics tray?
One of my local experts says I can't use nutplates on my 4043 aluminum avionics tray without powder coating it or I'm going to get dissimilar metal corrosion between the nutplates/cherrymax rivets/4043. Other areas of the SeaRey have nutplates riveted to the aluminum frame (6061T) with cherrymax rivets, so under his logic the build is already flawed in design.
Thoughts?
TIA
SeaRey builder lurking to get ideas to make his plane better, and keep his build from stopping like a gear down landing in water.
Dues paid for 2022
http://seareybuild.blogspot.com/
Old 01-19-2022, 01:07 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Here's an article on galvanic corrosion -- good read...
https://en.wikipedia.org/wiki/Galvanic_corrosion
Additionally, plate nuts are usually passivated in some way, either via phosphoric acid etch, molybdenum coating, cadmium plating, etc. so they aren't conductive like bare metal.
Brian Decker
RV-7 (Flying)
Old 01-19-2022, 01:30 PM
Low Pass's Avatar
Low Pass Low Pass is offline
You need an electrolyte for galvanic corrosion. I.e., dirty or salty water. If dry, you should have no problem.
Bryan
Houston
Old 01-19-2022, 01:34 PM
Thanks gents.
Dues paid for 2022
