Originally Posted by avi8tor50
OK-this goes out to all of you electric gurus!
Do I stil need to ground the strobes locally at the actual strobe itself, that is, does the shielding need to be grounded out at the wingtip as well or will this set me up for a ground loop? I do NOT have a ground running all the back to my grounding plate on the fw.
All help will be appreciated.
Usually not, especially if the manufacturer says not to...
The usual ground rules for a shielded cable is to ground the shield at one end only, and preferably at the noise generating end - the power supply in this case. Sounds like your connection description is OK...
gil A
