Old 08-06-2007, 01:32 AM
rv8_builder rv8_builder is offline
Question Corrosion protecting platenuts
Hi fellow builders,
I am preparing to attach the platenuts to the main wing spars that hold the fuel tanks and was wondering what others have done for corrosion protection.
I see that some builders use the platenuts without any protection and that others prime them.
The task of priming 210 platenuts doesn't appeal to me so I thought of electroplating them (Yellow passivate). This is very cheap in South Africa and I can have them done within a day.
Can I safely electroplate them or is there a specific reason why Van's supplies them unprotected?
Andre Burger
South Africa
RV-8 Wings
Old 08-06-2007, 01:50 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Specs....
Andre .. much discussion here...
http://www.vansairforce.com/communit...3&page=1&pp=10
The MIL-Spec ones are OK (cad plated) but non-one could get the spec. for the K1000 ones...
The Mil-Spec is here...
http://www.av8design.com/Hardware/MS21047.pdf
UPDATE...
The K1000 nutplates are cadmium plated - the dry film lubricant makes them look black - but they are cad. plated like the rest of our hardware... so if you are not priming AN bolts and nuts, the nutplates should be similar...
Here is the K1000 specification.... took a bit of googling...
http://www.clarendoneng.co.uk/pdfs/a...nuts/k1000.pdf
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-06-2007, 03:17 AM
skyyking56 skyyking56 is offline
Default I primed mine
Hi Andre,
I took all of my platenuts and layed them on a big towel in my paint booth and used a low pressure setting on my spayer (AKZO two part epoxy primer) and after about 15 minutes flipped them over and did the bottoms.
This whole process took me about 1 hour.
It was tedious, but I feel better about the extra coating.
Jim
7A and a couple of days ahead of you in progress
Old 08-06-2007, 04:53 AM
Thumbs up
UPDATE...
gil in Tucson
Hi Gil,
Thank you for your quick response and valuable information.
Never would have thought the platenuts are already Cadmium plated?.I?ll start riveting them on tonight
The support you guys give us make building an RV so much fun
Andre Burger
South Africa
RV-8 Wings
