Originally Posted by PaigeHoffart
Instead of two alternate feed switches, why not just one 2 pole alternate feed switch? Hook one side to the endurance, and one to the avionics. Would there be a situation where you would want endurance but not avionics?
Paige
Depends on the failure, two separate switches would give isolation of the buses...
But, your question echoes Dan's posting... normally some of the avionics would be on the regular bus, and some on the endurance bus.
With a separate avionics bus, you would have to do manual load shedding, not a big deal, but might take time and concentration in an emergency situation...
gil A
