With this setup, you can have the GPS display on the EMS but not the SL-30's output. I'm told that when the DSAB goes bidirectional, this will be possible. (Could be wrong on that, but two-way DSAB is supposedly in the next firmware release, and that will give EFIS data on the EMS without the secondary serial hookup.)
[Second thought edit:]
If you want to have the SL-30 show on the D100 and D120 at the same time, you'd have to hook it up reverse of what I said: Place the SL-30 to the D120 and the GPS directly to the D100. I have not tested this configuration but I believe it will work.
Hope this helps.
Marc
