Old 08-03-2007, 07:26 AM
danielhv's Avatar
danielhv danielhv is offline
Default Is this going to be big enough?
Im in the process of buying a new home... Is a 20x20 garage big enough to build an RV in? If not, I wont buy the house! Seriously though, Im trying to plan ahead. Also, how do you guys aircondition and heat the garage so you can work in it year-round?
Old 08-03-2007, 08:09 AM
bsacks05's Avatar
bsacks05 bsacks05 is offline
My -9 was built in a one car garage approx. 9x12. I used a little oil heater in winter and fans combined with minimal clothing in summer (boxers only - not a pretty picture)
I did build a small shed outside to accomodate the usual garage stuff such as bikes, mowers, etc...
Since the plane has been finished, the garage is now a play room for the kids and has a window A/C unit.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 08-03-2007, 09:59 AM
vmirv8bldr's Avatar
vmirv8bldr vmirv8bldr is offline
Default RV-8 in a 20x20
I'm currently building an 8 in a 20x20. Empenage is strapped to the ceiling using hook-screws and cargo straps and the wings are stored side by side in a wing cradle. I have a 4'x8.5' work table, a 2'x4' roll-around work table, a stationary 2'x5' table holding grinder, drill press, and sander.
Last night I moved the fuselage off the table onto saw horses and still had enough room to walk around the plane. Oh, and I have 18" deep shelves against one wall.
20'x20' is plenty of room.
In fact, there was a car parked on one side of the garage while I worked on the empenage!
Bart Filipiak
Eastvale, CA
RV-8 N74VB
Barrett IO-390
WW200RV
FLYING!!!!!!!
Old 08-03-2007, 10:01 AM
videobobk's Avatar
videobobk videobobk is offline
My garage is 22X26 and at all times I had one car plus the garden tractor inside (maybe not on the couple of days the wings were on.) I built the wings between the bays and had two cars plus GT inside for all the time before I joined the front and back parts of the fuse. Then my car had to set outside! You will have plenty of room.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 08-03-2007, 10:43 AM
frankh's Avatar
frankh frankh is offline
Default I have a 24*24 shop
with a room off to the side to house the oiless compressor in.
I put two window rattler AC units in the back wall that opened to another area where I store my tractor (in fact I extended the shop to move out the tractor so I could get the 7a kit in).
I opened the doors to the tractor area to allow the heat from the AC units to be carried away.
With some extra roof insulation the 2* window units would depress the inside temps by 25F...Making 100F days fairly comfortable on the inside.
I don't like heat! and I was working 4*10 hour days at work so i could take the Friday off to work on the kit....As I stop work at 80F, the 2 bucks a day to run the AC units was a great investment.
In the winter I use a propane blast tube heater occasionally.
Frank
Old 08-03-2007, 12:14 PM
conlimon conlimon is offline
Default do what I did!
you could do it the way i did it... start the project knowing that you don't have enough space (my garage is about 18' x 18') and figure that you'll sort it out when the plane gets too big. that's when the sawzall and a crowbar become necessary additions to the RV builders tool kit. my ultimate solution? i recently built a very easy addition onto the back of my garage. not pretty, but it works!
check here...
http://www.perfectlygoodairplane.net...ig%20hole.html
cj
#40410
RV10 fuse/finishing
Old 08-03-2007, 06:32 PM
grover grover is offline
Default air condition?
who uses air conditioning?
[IMG][/IMG]
james kleen
savannah
RV8sp
- RV3
Old 08-03-2007, 07:11 PM
mannanj's Avatar
mannanj mannanj is offline
Default Build Space
Where there's a will; there's a way.
I built the wings and fuselage in the living-kitchen-dining area of a 14x54 ft. single wide mobile home. Had just enough room on the firewall and tailpost area to squeeze sideways through. I was single at the time. Had to cut the end of the bar off with a sawzall in order to get from the front door the the stove, sink and refer.
Wasn't long before the carpet was full of alum. chips and shavings. Made going barefoot on the carpet sort of dicey! Had to remove the door frame in order to get the fuselage out.
Aaah, those were the "good ole days."
BTW, life is much better now!
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 08-03-2007, 08:08 PM
Geico266's Avatar
Geico266 Geico266 is offline
The bigger question is should you buy a house today or wait. With foreclosures up 55% over last year, and the prospects of double that due to the refinance boom the last 4 years with crazy mortage loans, it can only get worse, and prices can ony come down. There will be more homes on the market at rock bottom prices.
Rent for a year.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 08-05-2007, 05:28 AM
skyyking56 skyyking56 is offline
http://www.heatershop.com/heavy_duty...model_e_9.html
This is what I use in a 20 x 24 very well insulated shop.
It does require a 40 amp 220 volt circuit though.
It works very well....
They use it for yoga rooms ...Did you get that DR?
Hope this helps.
Jim
ps I also use a 120 volt 15 amp window air conditioner and it works fine.
