Old 08-02-2007, 10:09 AM
jlfernan's Avatar
jlfernan jlfernan is offline
Question Mapbox install
Just started to install the mapbox on my 9A slider. First of all, the material of the box is so thin, I had a heck of a time setting my rivets. Every time I hit the trigger on the rivet gun, the box would bend and move. It isn't perfect but it should do. Now to cutting the hole in the subpanel. In the words of Carlos Mencia, I'm having a "Doot doo doo" moment. The instructions tell you to use the #30 holes in DJ to roughly define the corners for the cutout and then the plans tell you to cut it to 3 23/32" x 6 19/32"(I'm starting to need glasses for all these tiny measurements). Do any of the angles get riveted to the F-721A? What I really need are some photos of the installation. Maybe this will shed some light. Thanks all!
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
