I agree that the overhaul costs for the Lyc are overstated on Robinson's site. There is also an eror in one of the cruise speeds, should read 150mph, not 250 Pretty hard to get a Seabee to do 250! We must compare new to new here with regards to prices. I see the initial costs about the same. Overhaul costs will be way lower on the V8.
Diesel engines are in the .3-.34 range of SFC. Some stationary ones are as low as .265. Some aircraft engines achieve as low as .36. I calculated the SFC for the LS-1 using figures in a magazine article giving the fuel consumption, MP and rpm and extrapolating from the GM dyno curves. With the compact chamber and 10.1 CR EI and EFI running inclosed loop, .385 is certainly possible. Our Sube gets .42 leaned to 13.8 AFR.
The LS-1 and LS-6 certainly do produce the power stated and the numerous endurance racing wins prove its durability. There is no history of HG failures on these engines to my knowledge. They have a reputation for being bulletproof.
The longblock weight IS 390 lbs. GM lists the all up weight with accessories as 457lbs. A Lyc. IO-540 weights between 405 and 430 bare, depending on model. Add accessories and you are at 430-455. On the LS-1, the redrive, rad and coolant will add 75 to 100 lbs. All things being equal, this is about how much extra it will weigh over the Lyc.
I'm using a Sube EG33 in my -10, not an LS-1 but I don't see quite so many negatives here other than the weight.
