Old 10-08-2021, 07:13 PM
jrock836's Avatar
jrock836 jrock836 is offline
Default Trim Indicator Not Indicating
I'm try to troubleshoot why my trim indication isn't working. It stays planted at the bottom of the display. The servo still works. I have looked at all of the connections and plugged in / unplugged all three of the wires responsible for indicating the position of the trim servo and everything seems clean and secure. My trim servo is the Ray Allen ES MSTS-T3-7A-2 unit.
I do show 5 volts on white/blue wire coming from the EFIS.
As I understand it the two white wires 31/32 is just switched power to the servo to make it move each way. If that's the case, the only other wires to be concerned with would be the whi/grn (4) position wire and whi/orange (25) grnd wire. The (25) ground wire does show continuity to ground. Not sure how I should test the position (4) white/green wire.. Is there a voltage out of the servo I should be looking for? I'm showing about 1.4 volts which will vary as I move the trim up and dow..
Edit.. Nevermind.. I figured out the problem..
Apparently somewhere between the tail and the front fuselage harness, the grn/whi #4 wire is broken.. No continuity.. ugggg...
Click image for larger version
ID:	16895  Click image for larger version
ID:	16896  Click image for larger version
Joe
Van's RV-12 #120566 - ELSA - N49DD
Spinks Airport, KFWS, Fort Worth, TEXAS!
DONATED
Closed Thread
