I leave mine on until I'm ready to use that particular part. Some folks have left their's on for considerable time but Van's warning is true in that it does becomes harder to remove over time. I think another consideration when leaving it on is how the parts are stored as some have reported discovering corrosion after removal of the plastic due to moisture that found it's way between the metal and plastic.
With the soldering iron make sure that the tip is well rounded and just don't bear down as hard. Don't be in a rush either so the heat will do it's job. On the external skin surface, I've removed the plastic just along the rivet lines with the iron and I've also removed the plastic in its entirety. Removing just the rivet lines does keep the finished component looking a lot nicer, but if you are going to paint it, this is really a non-valued added step IMO. I don't think it makes one bit of difference in the build and is simply a personal preference on technique. Personally, I've stopped removing the strips altogether.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
