Old 09-14-2021, 07:20 AM
Default Consumables for Condition Inspection
I was going to put this in the 9 thread but thought most items would be needed for all the models.
I am doing my first condition inspection next month. I started a list on what I should order to have ready but would like suggestions on other items or tools needed to get it done. There is a good list in "Are My Nuts Tight" so I think I am off to a good start. This assumes I have all the hardware and normal items most of us have in our hangars.
1. Mouse Milk
2. Spark Plug Gaskets - plugs if needed
3. Anti seize paste
4. Carb Cleaner to clean engine
5. Exhaust gaskets
6. Oil - filter - air filter
7. Wheel bearing grease
8. Brake Pads - if needed
9. Extra tube
10. Indicator Paint
11.
12.
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
Old 09-14-2021, 07:29 AM
N184DA's Avatar
N184DA N184DA is offline
- Carb Inlet Screen Gasket
- Oil Pump Suction Screen Gasket
- LPS 1, 2 & 3
- Brake Fluid (5606 or Royco 782)
Derrick L. Aubuchon
RV4 (Flying, approx 900hrs)
Tacoma Narrows Airport (TIW), WA
dlaubuchon@gmail.com
(2020/2021 dues paid)
Old 09-14-2021, 07:30 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default O-rings
Having had a break failure on a recent landing. Im putting replace brake puck O-rings
on the list. Using Vton higher temp O rings.
Al Girard, Newport, RI
N339AG
RV-9
Old 09-14-2021, 08:02 AM
John Tierney John Tierney is offline
Cotter Pins, for wheels, etc.
AN900-xx Crush Washer for Oil Sump Strainer
K&N Air Filter Recharge Kit
ELT Batteries including remote (if applicable)
If P-Mag equipped, spare magneto gasket in case damaged during inspection
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 09-14-2021, 08:04 AM
Steve Steve is offline
An assortment of screws used on tail fairings, wheel pants, inspection covers, aft bulkhead, seat pans, etc.
Cotter pins and safety wire.
Five Sierra Fox
RV-9A
Utah
Old 09-14-2021, 02:08 PM
plehrke's Avatar
plehrke plehrke is offline
-Various solvents for cleaning (I like acetone, mineral spirits, Hoppes no9 for fuel injectors, brakekleen, lacquer thinner
-Alternator belt
-Safety wire sizes 0.032 and 0.041
-Zip ties
-extra adel clamps as always see something new that needs clamping
-exhaust hanger replacement parts
-Dow Corning #4
-fuel lube
Philip
RV-6A - flying 970+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 09-14-2021, 02:19 PM
Plummit's Avatar
Plummit Plummit is offline
Band Aid (or equivalent) bandages. The day I do a condition inspection without leaking human 5606 is the day I hire someone else to do it!
-Marc
RV-10
N814RV
2021 Donation Made
Old 09-14-2021, 02:21 PM
odens_14 odens_14 is offline
-Marc
What's that? I thought everyone used a shop towel and electric tape
Chris Odens
Alexandria, MN
RV-7 N914N
FLYING!!! as of 7/22/10
Old 09-14-2021, 04:41 PM
rjcthree's Avatar
rjcthree rjcthree is offline
Default But even thenů.
Marc, but even then, you bleed. You just bleed green.
And me, I usually just change gloves and bleed into the new one. All bleeding stops eventually, as my MD brother in law likes to say.
Add outer bowl oring for Andair collator, if that’s what you’re using.
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2021 VAF contributor
Old 09-15-2021, 03:18 AM
craig.roser's Avatar
craig.roser craig.roser is offline
Why higher temp O rings? Was it a temp related failure?
Craig Roser
2022 Carbon Cub FX3 Amphibian Gerridae ON ORDER
2015 Gunter Malich RV8 El ZunZun
2005 Cessna C182T G1000 Alexandra
West Central Florida
