Old 09-10-2021, 01:29 PM
bernsbm bernsbm is offline
Default Brake fitting leakage.
Any thoughts on how to approach a leaking brake line fitting (see photo). The fitting was initially installed before the landing gear was mounted. Given the tight space, is it possible to get a wrench with decent leverage on the fitting, and if so, what type of wrench? If not, I will need to remove the gear to address the leak. I'm thinking removal and reinstallation of the fitting may be required. Thanks in advance!
Click image for larger version
Barry Bernstein
N12BB RV12 Skyview flying since Oct 2016 (Sold)
N122B RV12iS Garmin flying since Oct 2020
https://eaabuilderslog.org/?s=bbernstein
2021 dues paid. Best bargain in aviation!
Old 09-10-2021, 09:38 PM
RFSchaller RFSchaller is offline
The fittings on my master cylinders require periodic tightening. Usually about 1/8 turn.
Old 09-11-2021, 02:04 PM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
Barry,
Lots of good discussion on this issue in the following thread: https://vansairforce.net/community/s...d.php?t=198437.
If it were my plane I would take a day, remove the gear and fix.
Mike Draper
RV-8 N468RV
First Flight 11/13/2011
TMX0360, Dual Pmags, CS
Old 09-11-2021, 03:38 PM
jrs14855 jrs14855 is offline
Default Fitting
The information shown in post #4 will lead you to the previous discussions about how this can be done without removing the gear. In that case it was a Grove gear on a RV8.
As far as tools there are a couple of options. Remove the nylon line and fitting. Screw a nut on the 90 degree fitting and turn it with an open end wrench or even an adjustable wrench, starting with the wrench on the nut.
Second option is to cut off the end of a cheap open end wrench and weld on a flat steel bar at a 90 degree angle. It may be necessary to create two wrenches with different angles.
Another alternative is to cut off the end of the 90 degree fitting and remove the remaining piece with vice grips. In that case replace the 90 degree fitting with a 90 degree street elbow and appropriate straight fitting for the nylon line.
The street elbows are automotive or industrial fittings
Old 09-12-2021, 08:45 AM
Barry, you just might have enough room to tighten the fitting. The compession fittings use with the plastic hose are alittle shorter on the hose side, so it just might clear the the roof and the side so you remove it, reseal it, and reinstall getting it tight. A really good open end wrench with a wide face, but NOT a large head area may clear. Probable have to make that wrench. Hello bench grinder.
Make sure to use a really good sealer, and get it tight.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 09-12-2021, 09:12 PM
I cut down a box end wrench to tighten my brake fittings under the wing box bulkhead.
Old 09-14-2021, 05:44 AM
Thanks for all the information, links and ideas on how to address the leaking fitting. Still deciding which way I'll approach the issue (literally and figuratively). With my first condition inspection coming up, I'm leaning towards removing the gear leg to fix the leak.
Might want to assemble a few of the suggested wrenches for use down the road!
Barry Bernstein
Old 09-14-2021, 10:58 AM
NinerBikes NinerBikes is offline
If you haven't already, you might want to consider painting the gear legs while they are off of the plane, to prevent corrosion.
Donated
RV-12, KWHP based
"Time to Spare, go by Air."
Old 09-14-2021, 04:56 PM
fr0gpil0t fr0gpil0t is offline
Barry
I have recent experience of this fitting and would recommend removing the gear leg. I noticed a leak there and it is possible to remove the fitting from the gear leg. But what neither I or my partner could do is get the AN fitting started as we tried to put it back in. We could not get our hand at the right angle to do that one turn to get the first thread started before getting a wrench on it. On top of that you have sealant on the threads so you will get that all over the gear leg or you.
I'm still in the building process but it probably took 30 mins to remove the tank and get the leg out and then another 45 mins to put it back and torqued correctly vs the 1.5 hour we wasted getting the fitting out and our attempt to get it back in.
I'm still having problems getting the fitting to be leak free at the base of the gear leg but will post on a separate thread.
Robert
