Old 09-08-2021, 01:24 PM
tyconnell's Avatar
tyconnell tyconnell is offline
Default 10-05 17/64" System hole
I don't have a 17/64" drill bit (HomeDepot up the road has one), but I've never needed one, and I'm very curious why the -14 seems to have this different, weird hole size.
I've match drilled the #30, and the hole comes out on the upper VS-410PP Hinge Bracket. Searching through the digital plans, it looks like it's the system hole referenced in the OP-56 Tail Lighting section, and this makes complete sense. What doesn't make sense is that every other model (except the -12) calls for a 1/4" hole to be drilled vs. a 17/64" hole to be drilled.
I'm going to drill it to 1/4" so I can "build on" since upgrading the hole later to 17/64" can be done fairly trivially (I think the F-01412D tie down bracket will be out of the way).
All that aside, does anyone know why this hole would be 1/64" larger than the other models?
Click image for larger version
Name:	Screen Shot 2021-09-08 at 1.16.46 PM.jpg
ID:	15601  Click image for larger version
Name:	Screen Shot 2021-09-08 at 1.06.01 PM.jpg
Ty Connell
ty.connell@gmail.com
Donated 2021
Old 09-08-2021, 03:10 PM
JHartline JHartline is offline
Yes, the shielded 3-wire (L1082) goes through there. It’s possible you need a little extra clearance to get it through? You eventually put a blob of RTV or equivalent around the wire to keep it there. See page 11-10.
I tried to make sure only sealant was touching the outer cover or the wire so it wouldn’t ever chafe against the edge of the hole. Sounds like me anyways
James Hartline
Carrollton, GA 5GA2
RV-14 - First flight 4/7/2019. Phase I complete as of 9/11/2019!!
Old 09-08-2021, 03:17 PM
fl-mike's Avatar
fl-mike fl-mike is offline
drill 1/4", then make a couple laps with the dogleg deburring tool.
Mike W
Venice, FL
N164WM
N184P reserved (RV-8QB)
Old 09-08-2021, 06:05 PM
tyconnell's Avatar
Thanks for the inputs! I'll see what that cable is figure it out.
Ty Connell
Donated 2021
