Go Back   VAF Forums > Main > Safety
Old 09-02-2021, 06:42 PM
DylanRush DylanRush is offline
Default Training for aileron rolls or other simple aerobatics
I was up with a CFI yesterday who has owned his RV for a few years. We went up just to shake off the rust and do some maneuvers.
He offered to do some aileron rolls. We got up and did a few: 120kts into the maneuver, pitch up 10 degrees, yank to the side, use elevator to keep a positive G, roll out, and pitch up to get level and avoid building airspeed. It was awesome. I got my RV grin again and it lasted the whole day. He demonstrated two or three, then I did a few, and I felt very comfortable with the procedure.
My question is: should I pursue any additional aerobatic training before attempting this procedure solo? Maybe spin recovery training? I'm not sure I'm interested in other aerobatic maneuvers yet, but that interest will probably grow over time. My instructor said I did great and he said he didn't see a problem with me executing the maneuver on my own. For more context I have about 80-90 hours in my RV-6A.
Also, should one strictly adhere to the aerobatic weight and balance category, even for lower-G maneuvers like aileron rolls? My G-meter maxed out at around 2G.
RV-6A N17EL Currently flying, based out of KPAE
Auto-paying monthly dues
Old 09-02-2021, 07:03 PM
jrs14855 jrs14855 is offline
Default Aileron Rolls
Aileron rolls have gotten more than a few people in trouble. Find another instructor. There is no need to slam the stick.
I use more speed and a substantially steeper climb. Touch of rudder in the direction of the roll and a nice smooth application of aileron. That keeps the nose from dropping very far below the horizon. You can establish the climb, let go of the stick and push the stick to the left or right with your finger, no elevator movement.
You may want to read the accident report on in flight breakup of RV 7 near Atlantic City NJ. That was the result of a botched aileron roll.
Get some instruction.
Old 09-02-2021, 07:24 PM
ty1295 ty1295 is offline
I very much believe you should get spin training prior to doing more. You don't want to see a spin the first time solo, and not expecting it.
Jeff Scott
RV9A First Flight 9/30/19
Old 09-02-2021, 08:39 PM
Excellent thanks so much for the replies! I'll get some spin training before attempting this on my own.
Old 09-02-2021, 09:01 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Excellent decision Dylan - there is always more to learn, and I’d be just a little nervous about a “spur of the moment” instructional moment from a CFI that probably didn’t check to see if the airplane was below aerobatic gross first. And oh….you WERE wearing parachutes to be legal…right?
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-02-2021, 11:35 PM
dreed dreed is offline
I'd add my vote for training too. I'd say if you can find some upset recovery training (URT)+ some spin training even better in my opinion. They can get you pretty comfortable in all sorts of attitudes- and it's a heck of a lot of fun. I am a complete amateur, but the first time I did a hammerhead was so much fun- like a little kid giggling levels of fun. Could not wait to learn more and get better.
Dan Reed
Camas, WA
RV-7A - N167DR
First flight 5/25/2021
Phase 1
2018/19/20 VAF dues paid
Old 09-03-2021, 03:58 AM
craig.roser's Avatar
craig.roser craig.roser is offline
Dylan, I just completed a Basic Aerobatics Course Course given by Alain Aguayo. See https://www.aguayoaerosports.com/services. The course was a hoot!
Even though I do not think I will ever compete I wanted the instruction, which centered around the Primary Category Known Program, and Alain seemed the best choice. See https://www.iac.org/known-sequences.
Long ago I had gotten an Intro to Aerobatics Flight as a gift. That hour and a half went in my logbook but didn't prepare me to fly my RV8 upside down. I have to admit it was hard keeping El ZunZun upright until I competed the course. (smile)
Craig Roser
2022 Carbon Cub FX3 Amphibian Gerridae ON ORDER
2015 Gunter Malich RV8 El ZunZun
2005 Cessna C182T G1000 Alexandra
West Central Florida
Old 09-03-2021, 06:39 AM
larryMar larryMar is offline
Definitely get spin training ! Spins are a normal maneuver and other countries insist on mastery before a certification. For the life of me, I can't understand FAA's very weak stall and spin training requirements.
In any case, get with an instructor who specializes or will do upright and inverted spins. ait may very well save your life!
Old 09-03-2021, 07:44 AM
Mcmark Mcmark is offline
I recently watched a botched hammerhead turn into an inverted flat spin. Scared me and I was on the ground! Get spin training!!!!
Mark McKibben
Starduster SS101
Tailwind
"Let us endeavor to live so that when we come to die, even the undertaker will be sorry." Mark Twain
Donated '21
Old 09-03-2021, 08:04 AM
DanH's Avatar
DanH DanH is offline
The risk here is an airspeed runaway, and until you get one going, you may not grasp just how quickly it can happen. Staying within the acro W&B envelope allows pulling to the designed structural limit if necessary.
Which brings up a few points. First, it does not sound like your instructor communicated the more subtle aspects of a simple one G roll. Think about Jim's comments above, in particular the phrase "..establish the climb, let go of the stick and push the stick to the left or right with your finger, no elevator movement." There are many kinds of rolls, and while some require distinct elevator inputs, this type isn't one of them.
Go here, and watch my right hand beginning at 19 seconds:
https://vimeo.com/189574781
The elevator is allowed to float to its trimmed position. The open hand means no elevator input. And there is no "yank to the side". As Jim said, smooth is the key, and note I didn't use full deflection.
Two, I won't tell you to avoid solo practice, as aptitude varies a lot. However, understand this...the error which can kill is to split-S halfway through a roll, with a subsequent overspeed breakup or ground impact. Absolutely, positively fix this mantra in your mind...Once committed to the roll, I will not pull, but instead maintain the roll input until again upright, no matter what..
Dan Horton
RV-8 SS
Barrett IO-390
