Old 07-24-2007, 01:35 PM
Bret S's Avatar
Bret S Bret S is offline
Default Another approach to the engine - prop - performance equation
Haven't posted anything stupid in a while I guess what I mean to say is I haven't posted anything in a while
So to the point... I'm still a ways off from buying yet been dreaming due to all the IO-390-X postings and wanted to pose a question about engine power, prop and budget trade offs.
To keep the initial investment lower, but with an eye to the future when I want to buy an $11000 composite acro propeller to mate with the 210hp beast. I haven't seen anyone consider:
IO-390-X with a 3 blade Catto prop
$32000 eng
$1900 prop
$33900 total
- vs -
Lycoming IO-360-M1B with a Harzell BA and governer that I consider minimum performance level
$24400 eng
$1100 gov
$6100 prop
$31600 total
How much of the performance loss from a FP wooden prop with an additional 30 hp be vs. the 180 hp CS system?
I might assume I'd be doing 8000' crusing at %65 power with the IO-390-X to roughly equal the %75 power cruse of the IO-360 for fuel economy and yet want to do some deceint sport acro.
Any insights?
Old 07-24-2007, 03:07 PM
rv8180 rv8180 is offline
That's my line of thought too.
Everything is set up for an easy conversion to a CS prop in case I want to change later.
[IMG]
Roy C Lewis Jr
Jax, Fl
RV8QB
Lyc AEIO-390
Catto 3
Dual GRT
Firewall forward
Old 07-24-2007, 05:31 PM
N941WR's Avatar
N941WR N941WR is offline
Here is another thought...
Why not ask Craig Catto to make you a four bladed prop? I'm sure he can give you the pro's and con's of such a set up.
I suspect you will have enough power to absorb the additonal power and wouldn't that look SO cool! Never mind it might cost you a few knots at Vcr.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-26-2007, 09:40 AM
Bret S's Avatar
I know its a comparison that may be difficult to quantify given choice of propeller pitch and other factors, but...
IO-360-M1B (180hp) and Hartzell BA prop weighing est. 355 lbs
vs
IO-390-X (210hp) and Catto 3 bladed prop weighing est. 328 lbs
Weights taken from Lycoming spec sheets and this forum.
Does any one have a gut feeling about differences?
I'm an economy cruser so flat out top speed isn't the issue and I think I can get comperable MPG out of either system.
How might the two systems compare in climb rate?
Old 07-26-2007, 03:56 PM
If that's the case, why not an 0-320 with a CS prop?
Roy C Lewis Jr
Jax, Fl
RV8QB
Lyc AEIO-390
Catto 3
Dual GRT
Firewall forward
Old 07-26-2007, 04:30 PM
Bret S's Avatar
High power + good CS aerobatic prop = vertical penetration in up lines as an ultimate goal, but costs $$$
If I buy the 180hp engine to start I'm probably not going to upgrade the 180hp engine to a 210hp later. For economy if I start with a FP prop on the 210hp then I'm spending about the same amount (budget wise) as the 180hp and WW200C aerobatic prop.
If I spend all my startup money on 180hp + CS prop then I have no upgrade path without buying and installing a new higher hp engine.
The question was posed: How close to a 180hp + CS prop will the 210hp and lightweight FP prop be since I'm still interested in performance. Maybe this approach makes no sense and that is what I'm trying to determine.
Bret
Old 08-07-2007, 10:23 AM
burgundyja's Avatar
burgundyja burgundyja is offline
i am thinkining the same thing. one idea i had is to do the 180hp light engine and then put on a light composite prop. the question i have is what is the best place to get the engine. eci supieor mattick or lycomying. and what composite prop is the best for aerobatics?
