Originally Posted by Rick6a
A couple of questions for those informed about powdercoating.
#1. The steel accessories on my truck that are factory powdercoated can be wiped with solvents without damaging the finish. Yet you can easily dissolve the "powdercoat" finish on the steel parts that are furnished with Van's kits if you aggressively wipe the surface down with MEK. Why?
Rick, I discovered a long time ago that powder coating is not all equal....
I had my motor mount powder coated in Los Angeles by a reputable company.
I discovered that it would wipe off with acetone...
I went back and checked, and they had powder coated it with an enamel type paint. They said I needed an epoxy paint, and stripped it and re-did it... it's now solvent proof...
Since "powder coating" only describes the application method, I think you have to be more specific and specify an epoxy (or urethane?) coating when you speak to the painters. Tell them the application... our application is similar to "under the hood" in automotive terms (i.e., solvent resistant).
gil in Tucson
