07-21-2007, 03:55 PM
Airplane Grounded Need Carb Parts! - Atlanta
I'm looking for a quick source for a carb bowl gasket for a MA-4SPA carb and the 4 little tabbed lockwashers that you replace when you reinstall the carb bowl.
The gasket part number is: 16-B75
The part number for the lockwashers is: 78-A110
Aircraft Spruce has the gasket, but not the tabbed washers.
This is a critical need 'cause I can't head to Oshkosh on Thursday without a properly funcitoning carb...
So, does anyone know of a likely source in the Atlanta area?
Barring that, what are some other sources which I could call on Monday and have the parts shipped for next day delivery?
The background is that I discovered fuel stains on the belly of the aircraft after today's flight. Once I tracked it down, the source of the leak was a slightly loose carb bowl. So, to do things right, I need to pull the carb float bowl, replace the gasket, and replace all 4 tabbed lockwashers.
Thanks in advance...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
07-21-2007, 04:13 PM
carb kit
We just replaced our float with a kit from Spruce and it included the gasket and the tabbed washers. The old float had about 30 hrs on it (new carb and new engine) and it nearly killed us when the engine died, but that's another story. Anyway, kind of expensive if you just need the washers. But this would work to get you to Oshkosh.
Also, are you sure that you can't reuse the washers that you already have?
07-21-2007, 04:52 PM
Parts
Call Mike's Aircraft Fuel Metering 918-838-6217
or
http://2aps.com/cfs_Carb%20Kits.htm
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
07-21-2007, 05:28 PM
Kyle,
Can you send me the dimensions and a picture of the washers? I have some tabbed washers which were left over from my carb install and you are welcome to them if they are what you need.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
07-21-2007, 05:42 PM
Originally Posted by bsacks05
Kyle,
Bruce,
I don't have the washers with me, but I can give you a general description:
Each washer has 5 tabs. Three adjacent tabs are shorter and more squared off than the other two, and are designed to be bent up agains the flats on the bolt head. The bolt is the size of an AN-3, maybe smaller, with a correspondingly small head. The other two tabs on the washer are longer, have rounded tips, and are designed to bend down over the corners of the carb. The idea is that the two long tabs lock the washer in place relative to the carb, and the three small tabs prevent the bolt from turning.
I believe the washers are flat when they are new, and the tabs are bent during assembly.
You can sort of make out the two long tabs on one of these washers in the 5th picture from this page in Sam Buchanan's site:
http://home.hiwaay.net/~sbuc/journal/engine4.html
The washer is under the head of the bolt at the near corner of the carb - just to the left of the dataplate. You can see the two long tabs if you know what you're looking for.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
07-21-2007, 06:47 PM
Kyle,
Good chance I might have those. Just saw them recently as I was cleaning the hangar. I'll go in the morning around 8 and see for sure if they are what you need. Send me your phone number so I can call from there. Where is your airplane?
bsacks05@cox.net
Bruce Sacks
Warner Robins, GA
A&P
APRS KJ4EFS
