Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 07-21-2021, 03:32 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Default Oshkosh Airventure 2021 - Garmin Smart Glide For G3X Touch
Good Afternoon!
Things are heating up as Oshkosh Airventure 2021 is right around the corner. Several of the Garmin TeamX members will be representing at the show, and we look forward to getting the chance to meet many of our fantastic customers in person throughout the week.
The team has been hard at work throughout the year on many new features for our equipment. One which we are excited to announce is the latest addition to the Autonomi family of autonomous flight technology: Smart Glide for G3X Touch series flight displays.
In the event of the loss of engine power in a single-engine aircraft, a pilot faces the urgent, workload-intensive job of maneuvering the aircraft from its current position to a suitable landing location. Building upon, and in-part borrowing from, the Collier Award winning Garmin Autoland system introduced in 2019, Smart Glide is designed to assist the pilot by enhancing situational awareness and providing helpful automation during an emergency inoperative engine event.
Aviate, Navigate, Communicate
The G3X Touch is always monitoring nearby airports throughout a given flight. When Smart Glide is activated, it automatically activates a Direct To route to the Best Airport estimated to be within glide range based on several factors including runway length and condition; proximity; terrain; and available weather from sources such as FIS-B, or SiriusXM weather, in addition to current measured winds calculated by the primary flight display (PFD).
Smart Glide is engaged by pressing and holding the Direct To button, using the dedicated Emergency Databar menu, or by using a dedicated panel mounted switch.
If the G3X Touch system includes GSA 28 Autopilot Servos, with sufficient altitude Smart Glide activation also simultaneously engages the autopilot to pitch for best glide airspeed and initiates GPS navigation to the recommended airport, where the pilot will then take control of the aircraft and land. If excess altitude remains at the time the aircraft reaches the field, the autopilot will initiate a series of standard rate turns to descend until the pilot disconnects the autopilot. The pilot can deactivate Smart Glide at any time with the dedicated panel switch or using the Emergency page. In addition, the autopilot can be disconnected using the same methods during normal operation, such as the AP disconnect switch installed on the controls.
To save you time, Smart Glide will populate the destination airport’s CTAF or tower frequency into the primary COM standby. Also available are shortcuts to tune the transponder to squawk the 7700 emergency code and tune the standby COM frequency to 121.5 as shown above.
In the event the system estimates there is not an airport within glide range, the autopilot will automatically pitch for best glide speed, and roll wings level, quickly setting you up for a glide and allowing you to choose a suitable landing location.
We will be rolling out software to enable Smart Glide and other new features after the show and will provide Pilot's Guide and Installation Manual updates alongside it to help familiarize yourself with the system and provide further details.
Safe travels,
Justin
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 07-21-2021, 03:50 PM
ColoradoSolar ColoradoSolar is offline
That is a cool new feature and I can't wait to play with it. Hopefully I never have to use it for real but it could be a life saver.
Eric Vickery
RV-6A Tip-Up Bought Flying
Old 07-21-2021, 05:13 PM
KiloFoxtrot's Avatar
KiloFoxtrot KiloFoxtrot is offline
A great G3X feature from Garmin.
Your engineers ROCK, Pitch and Roll.
RV7A tip up
Superior IO-360-M1S Aerosport build school=Excellent. See post: Engine build school pictures IO-360
Tail / Fuse / Wings are complete + painted. I used Sherwin Williams JetGlo solids and AcryGlo metalics.
Leather seats by Flightline Interiors.
Still to do: Firewall forward, cowling fit and paint, G3X avionics.
FLY
Old 07-21-2021, 06:09 PM
newt's Avatar
newt newt is offline
Outstanding I figured this'd be a G3X feature when I saw the videos popping up in the Gamin Aviation feed for certified aircraft.
Notwithstanding the optional panel button to activate/deactivate it: Is it an extra cost option, or is it going to be rolled in to the normal G3X Touch software upgrade cycle?
- mark
[ Paid up on 16 Jul 2021 ]
RV-6 VH-SOL
Old 07-22-2021, 06:22 AM
uk_figs's Avatar
uk_figs uk_figs is offline
Will these features eventually show up in other garmin navigator products like the GNX 375?
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 07-22-2021, 08:35 AM
larrynew's Avatar
larrynew larrynew is offline
Default Autoland
It will be interesting to see if Smart Glide can function as an “almost” autoland during a good airplane but incapacitated pilot situation. Maybe: 1. Activate Smart Glide, 2. Reduce power slightly to start a descent. 3. Flare the landing. 4. Throttle idle or mixture cutoff. 5. Apply brakes. Possibly put simple directions in the Emergency Checklist that’s on the Smart Glide screen.
Might be much easier to teach my non-flying wife instead of the pinch hitter curriculum we’ve tried.
Larry New
RV-7A - Built, flew 900+ hrs, sold
RV-10 - Built, flying 200+ hrs
RV-12iS - Empennage ordered
VAF on Annual Autopay
Old 07-22-2021, 09:17 AM
BobbyLucas's Avatar
BobbyLucas BobbyLucas is offline
Thumbs up
Pretty sweet! Now if you can just tie into the Rotax FADEC we could have full Autoland, minus braking.
Or would we also need a throttle servo? Still doable, no?
Bobby Steinmetz
Van Buren TWP, MI
Student Pilot, Mechanical Engineer, Donating Member
RV-12iS #121228
  • My opinions are JUST my opinions, not facts
  • Regardless of phrasing or colorfulness, my opinion does not imply that any opposing opinions are wrong or ANY less valid than my own
  • Respect people by giving your own opinion without attacking or belittling others
  • Passive-aggressive is not better than overt-aggressive
  • When I fail to meet these standards, please call me out, gently
Old 07-22-2021, 10:05 AM
FireMedic_2009 FireMedic_2009 is offline
Default Is glide distance actively being adjusted real-time?
Being involved in an engine out earlier this year and realizing the glide distance is greatly reduced due to increased drag by the prop. Simulated engine out isn’t the same and when has anyone actually shut down their engine to determine actual glide distance. Can I assume the G3X s/w will be calculating the glide distance ring as the best glide speed is maintained and descent rate is determined?
I know with Foreflt you have to input the parameters to determine the glide distance of your plane, which I’m not sure is anyone really knows for sure.
RV-6A IO-320 FP sold
RV3B O-320 160hp
Donated 2018 and continue annually
Old 07-22-2021, 10:34 AM
dweyant dweyant is offline
Wow,
what an incredibly useful feature! Really excited to get a chance to install this on my 9A and check it out.
The amount of new features that Garmin has added (all free) to my G3X Touch in the five+ years I've been flying it are amazing.
-Dan
Dan Weyant
RV-9A N96KD
Done and Flying 4/30/2015
Old 07-22-2021, 01:58 PM
g3xpert's Avatar
Default Smart Glide Software Update
- mark
Hi Mark,
This will be part of the next software update for the G3X Touch. There is no additional cost associated with this feature.
The panel mounted switch shown in the marketing material is a neat addition to an installation, this switch is grounding a discrete input on the GEA 24, GAD 27, or GSU 73, which will be assigned and programmed by the installer for this purpose. You are able to use a switch of your choosing to accomplish this.
Justin
Garmin G3X Support
g3xpert@garmin.com
