Old 07-21-2007, 01:10 PM
frankh's Avatar
frankh frankh is offline
Default Ya I did it!
I left my master on overnight and completly flattened the Odyssey 680.
Jump started the engine and ran it for 15 minutes or so, shut down and the battery was still dead.
The charging volts of my Plane power alt are a little low at about 13.8V, but I'm wondering if doing the deep discharge has killed the battery?
Has anyone done this and had the Oyssey come back to life OK, or is it toast?
Frank..7a with charger plugged in!
Old 07-21-2007, 03:02 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Gee Frank, I don't know that I'd ever admit to anything like that...
But....ahhh...."a friend" has done a complete discharge of his Odyssey 680 at LEAST 3 times, and a good recharge (not just with the alternator) brought it back to where it is fine, alive, and kicking....
Hope I .... I mean "my friend"....never makes that mistake again....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-21-2007, 03:54 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Hmmm!!!
My best friends third cousins best friend heard from a friend that the 680 will come back to life. I, (I mean 'he') went out and flew for a little while and the battery came back to life. I think that was about 1.5 years ago and 200 hours.
Doesn't that just irk ya?!!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 07-21-2007, 04:02 PM
G-force's Avatar
G-force G-force is offline
The Odyssey batteries needs a higher voltage to charge properly, especially when totaly flat. Charge it at between 14.3 and 15 volts and a 680 ought to take about two hours with a 10 amp charger.
Mike Sumner
Castaic, Ca
Old 07-21-2007, 04:55 PM
frankh's Avatar
Default Cool thanks guys!
I only have a trickle charger and I don't know what it cgarges at to be honest. Its the "Junior" charger that Bob Knuckolls recommends so I'm hoping a good overnight tickle...I mean trickle....will have her back to life.
The engineer in me is now thinking of how to design a fool proof buzzer thingy interlocked with a canopy switch.
Frank 7a
Old 07-21-2007, 05:11 PM
John Clark's Avatar
John Clark John Clark is offline
Default Low Tech
Frank 7a
The Airline pilot in me says "use a checklist"
John Clark ATP CFI
RV8 N18U "Sunshine"
KSBA
Old 07-21-2007, 05:53 PM
steveKs. steveKs. is offline
I am not very techy but I left my RV6 with a FBO and they left the master on. I jumped the starter and left thinking everything was fine until I hit the landing lights arriving home and everything went dark.
We evidently jumped the starter/alternator side of the relay instead of the battery side and the alternator was keeping that side going til i overloaded the alternator with landing lights. The battery was still dead since it had no juice to keep the relay connecting it connected, hence no connection to the alternator. If this makes sense to you maybe that is what you did also.
steve
Old 07-21-2007, 07:13 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
I've used my 680 over a 3 year building process, bench testing...
It's discharged it completed several times and it had always come back to life. Prior to my first flight, I opted to get a new one. I still use the old one for various bench activities.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 07-21-2007, 07:29 PM
TSwezey TSwezey is offline
"My friend" left the master on after moving the plane to a more suitable parking place on a visit to Marco Island. My friend always leaves the beacon light on now and now "he" knows he has left the master on. Thank God "my friend" had a charging port on his Tiger and that there was an old timer who knew how to hand start a plane. Personally, "My friend" thought he was crazy for hand starting a plane.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 07-21-2007, 09:09 PM
7pilot's Avatar
7pilot 7pilot is offline
Default Need power to make power
Quite often the altenator will not put out at all if the battery has gone completely flat. It needs power to make it realize it has something to charge. I would expect your battery will come back to life after the overnight trickle charge.
Stewart Cole
N156DE RV-7A Tip-up, IO360 CS 3 blade MT Prop
http://www.7pilot.com
