Phil,
The AKZO data sheet uses 59 F - 95 F and a Relative humidity of 35% to 75% as recommended conditions.
When I lived in LA, and painted outdoors just before sunset as the humidity went up, I noticed that the primer would seem to absorb water, and make sort of bubbles that didn't stick.
I think the epoxy primers are somewhat hygroscopic...
gil in Tucson.... where getting the RH up to 35% is the usual problem....
...except for this month...
