Looking for some advice on the order of several build tasks. I'm to the point of needing to make my ignition harnesses for E-mags. Should I build and install the baffeling before I make the harnesses or vice versa? My engine is on the mount but not on the F/W; all accessories are installed except for the exhaust and fuel injector.
My first thoughts was that it might be better to do the baffles first and then run the wires where they best fit was but then I thought that if I had mags, the harnesses would already be made and installed so...
I haven't opened up the baffle kit yet so my anbswer may be in there.
7A, TMX-IO-360, e-mag and p-mag with aircraft plugs.
Jekyll
