Old 07-20-2007, 10:12 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Mark Chamberlain down again
Just off the AZ RV List...
<Snip>
Mark Chamberlain is down again with another emergency landing. He told me he was cruising between Glendale and Deer Valley when his engine quit making power. Possible fuel flow issue, not Pmags this time.
He is fine but as we were talking the news heli's were overhead. Just wanted to get the word out to avoid speculation when it shows up on the news.
<Snip>
Thanks for the report from Darwin N. Barrie, Chandler AZ
GLAD YOU"RE OKAY MARK!!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 07-20-2007, 11:05 AM
Default Intro News Story
Here's a link...
http://www.azfamily.com/news/local/s....93738f05.html
Another link...
http://www.azcentral.com/news/
Look under Videos
Awesome flying Mark! Good Job at the controls.
Reiley
VAF# 671
Friend of the RV-1
Old 07-20-2007, 02:03 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Any info on the damage to the plane?
The article mentions clipping a crane, any report of damage to aircraft?
Mark,
If you are reading this post let me know if you need any I can do to help. I can always travel up to Phoenix to pound a few rivets for a friend.
Glad to hear you are OK.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 07-20-2007, 02:34 PM
beattiema's Avatar
beattiema beattiema is offline
Glad he's down safe, in the video everything looks pretty intact. There is a crane in the area but no obvious contact in the shots from the helicopter.
Mark Beattie
Anaheim, Ca.
RV6 fuselage in work
N642ML reserved
Old 07-20-2007, 02:41 PM
frankh's Avatar
frankh frankh is offline
Default Good Job
Really glad you made it down safe Mark!
Give us an update when you can.
All the best
Frank
Old 07-20-2007, 02:43 PM
Default Plane is Okay
Mark's plane is back at the airport and okay. He just released a post on the AZ list. He can tell the story here if he elects to.
Again, Good job Mark!!!
Reiley
VAF# 671
Friend of the RV-1
Old 07-20-2007, 03:25 PM
MarkC MarkC is offline
Default Yep, me again <sigh>
Just had to have something to talk about at Osh guys :-)
If you watched the news report on AZCentral; they were wrong on the way I landed, I came in from the south, not the North.
Here's the rundown.
Plane is out and back at DVT, thanks for the offers of help folks, you guys are the best.
Quick rundown on this one: took off from DVT this morning to get gas, landed at Glendale, filled up and took off back towards DVT. About 2 or 3 minutes after takeoff (just leaving Glendale airspace) the engine just quit without warning. Tried to restart, couldn't, turned back to Glendale and informed them of engine out situation. As I set up for best glide it became obvious that I wasn't going to make the runway so I saw the construction site up the side of the New River canal (just west of the 101 / 99th Ave and Northern), and that's where I ended up. I did NOT clip the wing on the crane as the news has been saying, in fact I flew it back to DVT just a while ago, not a scratch (although I still can't believe I didn't break anything, it's a pretty tight area, guess I'm very lucky).
What went wrong? I have a rubber mat stuck to the bottom of the air box that was there to help seal the bottom of the air filter to the air box. It had come unglued and managed to get sucked in to the bottom of the throttle body. I'm still not sure how in managed to work itself out from being clamped between the air filter and the bottom of the box and also the high-strength adhesive I used to stick in on there (it's been there for over 200 hours). Anyway, it's riveted to the air box now as well as bonded (probably should have been riveted in the first place, but we live and learn).
This "off-airport" stuff is getting old, I don't mind if I don't have to do it again.
See you at Osh!
Mark - RV-7 - 210 hrs + 2 off-airport landings, and that's enough.
Old 07-20-2007, 03:34 PM
unqualified unfluencer
Thanks for the update, Mark. VERY grateful all worked out OK.
Grace under pressure!
b,
d
Doug Reeves (your host)
Old 07-20-2007, 03:48 PM
b,
d
"Grace", oh!, that's what they call that brown stuff?
Thanks Doug.
Mark
Old 07-20-2007, 03:56 PM
cjensen's Avatar
cjensen cjensen is offline
Great job Mark! I hope to meet you at Oshkosh next week! Be nice to shake the hand of a good stick such as yourself!
Glad all is well!
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
