View Poll Results: Where did you put your Ammeter Shunt?
A) Monitor Battery Load Only
9 |
47.37% |
B) Monitor Total Load Consumed
10 |
52.63% |
c) Monitor Aircraft Load Only
0 |
0% |
07-20-2007, 12:03 AM
Hi Guys,
Busy with wiring, (some noticed from my recent posts), got a good diagram from Dynon manual below for this discussion.
I have gone back and forth on my decision on where to install the shunt.
As I see it you can either ONLY check what goes in or out of your battery (A) OR how much your airplane ONLY is drawing (C). Position (B) gives you the total draw but not the split.
See the Dilemma? What is more important, What did you guys do and why?
Thanks in advance, Kind Regards
Rudi
http://www.dynonavionics.com/downloa...on%20Guide.pdf
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
07-20-2007, 07:47 AM
Rudi, I am not there yet, but I am giving it some thought. I am considering adding a second shunt with a DPDT switch to select which one the monitor is getting the info from. I would have the A and C position. B could be determined by the difference in A and C. ( battery is showing 2 positive, A/C load is 30 => alternator is 32 amps)
But then again, I could put it at C and know that my battery is charging by looking at the voltage.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
07-20-2007, 08:43 AM
Surely the important thing is to know whether the battery is overall being charged or discharged? I don't think you are much interested in what the aircraft load is? I'd have thought position A? That's what I'm planning to do, but I'm still only halfway through AeroElectric Connection so plenty to learn!! Hopefully Ironflight will be along shortly!
Chris
07-20-2007, 09:48 AM
Senior Curmudgeon
I also am just at the point of making this decision.
At this time, I am leaning on monitoring the battery, as my voltage regulator has a warning light to tell me if there is a problem there.
In reading the above posts, it seems folks are trying to follow what the electrical system is doing when things are working properly. I am looking at setting things up so as to find out what is going on when there is a problem.
It will be interesting to hear from folks already flying, and read the poll results, as so far all 4 of the posts have been from folks still building.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
07-20-2007, 10:05 AM
Confusing .. a bit...
Rudi,
You have them labeled as....
A Monitor Battery Load Only
B Monitor Total Load Consumed
C Monitor Aircraft Load Only
but in reality A is not battery load, but battery charge/load, and does check that the alternator has an output.
and B is not Total load, but is actually Alternator Output
I prefer A, since it measures load with the alternator off, and checks that the battery is charging when in normal flight. In cruise, all should be close to zero....
Perhaps you should relabel choices A and B?....
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
07-20-2007, 10:57 AM
EI has good reference. Same considerations as Dynon
The EI MVP-50 installation manual has a good explanation of pro's and con's of where the Shunt should be installed. If you download the MVP-50P (Piston Engine) Installation Manual from http://www.buy-ei.com/Downloads.htm and go to page 21 & 22, you will find a good explanation and diagram.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
07-20-2007, 11:06 AM
Only A an B...
Interesting, they only use A and B, and don't mention C....
gil A
Gil Alexander
07-20-2007, 12:33 PM
Is there a difference between B & C ?
When I look at the diagram that Rudi posted, B & C appear to be electrical equivalent. I am missing something?
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
07-20-2007, 01:19 PM
Yes, B will only show alternator output. If the alternator dies, Zero while there is now a load on your battery.
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
07-20-2007, 04:21 PM
Trace paths...
You can trace out the current paths.
Only two exist for current sources...
1. The Alternator can generate current (one direction only)
2. The Battery can charge or discharge (two directions... both a source and a sink.)
The aircraft load is a sink in one direction only.
Use these options, and every possible circuit path can be traced...  But ignore the starter, it's current is too high to be measured anyway...
gil A
Gil Alexander
Reason: Quoted wrong person...
