Old 07-19-2007, 11:00 AM
briand's Avatar
briand briand is offline
Default Stupid Fiberglass Question
Why are some parts green and some brown with a honeycomb-like structure embedded?
Old 07-19-2007, 11:23 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
The honeycomb is there to serve two purposes------separate the layers of fiberglass, which is how the strength is obtained, and do it with minimum weight.
The color is probably due to wet layup resin being different than the resin in the prepreg (short for "pre impregnated").
The honeycomb and prepreg are used for high strength layups, done in a mold that is vacuum bagged, and heat cured in an autoclave.
Wet layups are heavier, and have less relative strength.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-19-2007, 02:03 PM
rv72004 rv72004 is offline
Green parts are epoxy. Brown are probably due to the honeycomb shining thru. White parts are polyester.
Only use epoxy with epoxy parts. You can also use epoxy on the polyester parts.
EJ
RV7 flying
xp360, CS, All Glass cockpit
