Old 07-17-2007, 04:11 PM
szicree szicree is offline
Question Rocker cover to cowl clearance?
I'm fitting (cursing) my cowl and am finding that the rocker cover on the number 4 cyl is very close to the upper cowl. Assuming they are far enough to not bump at startup/shutdown should I be concerned? All opinions are very welcome. Thanks.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 07-17-2007, 05:29 PM
Ironflight's Avatar
VAF Moderator / Line Boy
My opinion is that as long as it doesn't bump, it's not a problem - these are very tightly cowled engines!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-18-2007, 06:53 AM
pierre smith's Avatar
Default Cheeks too
Hi Steve,
We just went through the same thing on my buddy's -4. Be sure and fit the rear cowl cheeks while the forward top and bottom cowls are on and check the height to be sure that the cheeks don't cover the screws of the top skin. Aligning all four cowl pieces was a lot tougher than on my -6.
When the time comes to mount the oil cooler, I'd suggest that you lay it back about 30 degrees and use a short length of 3" scat tubing. A flat mounting plate can be attached to the upper motor mount tubes for this with some Adel clamps. If you mount it on the rear baffle, half of it will be blocked by the cylinder when it's low enough not to rub the cowl.
Regards,
Pierre
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 07-19-2007, 12:59 AM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
Good Question, can I add a question?
What is typical minimum clearance? Who had what clearance, and then had it touching?
Rudi
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 07-19-2007, 05:22 AM
Default 1/2"
Rudi,
If you have an opportunity to watch an 0-320 or 0-360 start up and shut down without the cowl off, you'd be surprised at the amount of rolling/shaking as the engine either comes to life or shuts down. Obviously, the rocker box covers will move the most, as will the airbox....furthest from the center of the engine. I'd try for at least 1/2 an inch.
Regards,
Pierre
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 07-19-2007, 11:37 PM
Thanks Pierre!
