Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Fiberglass
Old 06-07-2021, 07:52 AM
RV10Pilot RV10Pilot is offline
Default Repairing Poorly Countersunk Holes in Fiberglass
One would have thought that by the time I got to attaching the empennage fairing I would have known how to countersink. Not. I am using tinnerman washers to hold the fairing in place, but I know I can do better.Not. The nut plates are attached. How do you recommend I fill the poorly countersunk holes and start over.
Click image for larger version
Old 06-07-2021, 08:04 AM
Ron B. Ron B. is offline
If your not concerned about the rough hole (washer will hide ) then you can smooth out the counter sunk hole so that the washer sits better by having a piece of wood behind the glass clamped tight with the proper size hole for the center tip of your counter sink. This will stop the wandering of your counter sink.
If you want to repair the hole outside the counter sunk area you should grind a taper in your glass and glass over the hole and start over. I would try to glass from both sides, a little on each rather than all on one. Makes a stronger bond.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 06-07-2021, 08:38 AM
wirejock's Avatar
wirejock wirejock is offline
Default Countersink fiberglass
Once fixed try a dremel and stone to countersink.
Run the dremel on a sharpening stine to shape the point to the correct angle.
Make a nice countersink. I usually stop shallow and use a hand deburring tool with a countersink bit to finish.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 06-07-2021, 09:44 AM
DanH's Avatar
DanH DanH is offline
slap some tape on the backside, wipe wet flox mix into the depression. cure, sand flush if needed, re-drill, countersink again.
Or just stop countersinking fiberglass. AN526's with nylon washers is the long term bulletproof solution.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-07-2021, 11:59 AM
bjdecker's Avatar
bjdecker bjdecker is offline
Bond in some Tinnerman washers.
ID:	12337  Click image for larger version
Brian Decker
RV-7 (Flying)
Old 06-07-2021, 04:58 PM
jrock836's Avatar
jrock836 jrock836 is offline
To fill the holes, tape one side of the holes and the fill the hole flush with epoxy. Mix the epoxy thin enough so that it will flow into any minor cracks. Then re-drill in any manner you want. Your local marine supply store will have the epoxy you need, unless you just want to order online. Carefully dremel out the loose pieces of fiberglass on the edge of the holes before you fill.
Joe
Van's RV-12 #120566 - ELSA - N49DD
Spinks Airport, KFWS, Fort Worth, TEXAS!
DONATED
Old 06-08-2021, 06:58 AM
goatflieg's Avatar
goatflieg goatflieg is offline
Lancair sells abrasive countersink bits that are made for countersinking fiberglass. Worth the investment.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - registered; final assembly continues; still putting out my own brush fires.
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2021... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 06-08-2021, 07:26 AM
YvesCH YvesCH is offline
You can use Perma Grit Tools:
https://www.permagrit.com/kt2/
Cheers Yves
Yves - Basel, Switzerland
RV-8 #83458 HB-YUA
Donation 2020 done
Old 06-08-2021, 08:37 AM
John Tierney John Tierney is offline
I have used this one with success, just very slow rotation:
https://www.permagrit.com/large-coun...ree-no-nipple/
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 06-08-2021, 08:42 AM
Dan 57's Avatar
Dan 57 Dan 57 is offline
Yep, did the same as Brian, bonded the fairing washers in. Better looks and durable if properly done.
In your case RV10Pilot, it looks like the cloth wasn’t properly saturated with resin in the first place...
Life's short... Enjoy!
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
