Originally Posted by humaround
1 Do you ever fly an Experimental category aircraft in IMC or at night?
2 Routinely or occasionally? What is your usual level of currency?
3 Approximately how many hours would you expect to fly IMC/Night yearly?
4 What instruments does your aircraft have (relevant to IMC/Night)?
5 What are your personal IMC minima?
6 In your view, what are the essential characteristics of your aircraft in relation to flying IMC/Night?
1. Yes
2. Occasionally...current but not by much
3. Exact data supplied below...
4. Dynon EFIS-D10, TruTrak Pictorial Pilot + AlTrak (2-axis), Garmin 496, airspeed/altimeter/VSI, AF-2500, GMA-340, GX60, SL30, GTX-320A; a/c is equipped for night & IFR
5. When I'm current, as published
6. Night is not a big deal if the airplane's electrical system is built reliably. I don't believe night & IFR should be coupled conceptually. For flight in IMC, an AUTOPILOT is a must-have imho. The relatively neutral roll stability can quickly create problems if you let it get away from you, i.e. for simple tasks that necessarily draw attention away from your scan. If the wings are level, pitch is stable enough so as not to create any significant deviations -- but if the wings are not level, all bets are off. This is why I believe an autopilot is an essential tool for safe IFR in a short-wing RV.
My credentials & exact data as of July 15, 2007 follows...it is ONLY my flight time & stats in my RV-7, it does not represent my complete stats.
- Commercial Pilot, Single- & Multi-Engine Land Instrument Airplane
- Total flight time in N714D: 1345.6 hours
- Day landings in N714D: 1549 (92.7%)
- Night landings in N714D: 122 (7.3%)
- Night time in N714D: 61.7 hours (4.6%)
- Actual instrument time in N714D: 33.9 hours (2.5%)
- Simulated instrument time in N714D: 2.5 hours (0.2%)
- Instrument approaches in N714D: 48
To summarize:
Less than 5% of my flying is at night. That is NOT a reflection of the aircraft's capability or lack thereof.
Less than 3% of my flying is under IFR. That is partly due to my being based in an area where the weather is fair much of the time, and partly due to the fact that I only fly IFR when I "need" to.
