Old 07-15-2007, 06:51 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Lycoming Lock Washers
Lycomings are held togther with dozens of nuts secured with toothed lock washers. Do these have to be replaced every time a nut is removed and replaced?
Jim Sharkey
RV6 Tip-up FP O360-A1A
Old 07-15-2007, 07:08 AM
Radomir's Avatar
Radomir Radomir is offline
they should be replaced.. yes..
Radomir
RV-7A sold
Old 07-15-2007, 10:33 AM
jsharkey's Avatar
Thanks!
I thought so but just checking.
PS - Where can I get an official manual for my Lycoming O360-A1A?
Old 07-15-2007, 11:11 AM
Radomir's Avatar
You can get "official" ones from Lycoming... but can get reprints from Essco (http://www.esscoaircraft.com/). There's an operator's manual and parts catalog.. probably should get both (definitely parts catalog)... Just make sure you get the right one.. if your engine is wide deck carburated, then you want PC-306 parts catalog... there's tons of 'em so just make sure you get the one that matches your engine.
Radomir
RV-7A sold
Old 07-15-2007, 11:12 AM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Originally Posted by jsharkey
Thanks!
Jim,
Check your private messages.
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
