Old 07-13-2007, 01:55 PM
szicree szicree is offline
Thumbs up Thanks to Tampa Builder's Group
Just want to thank the Tampa Group for their Illustrated Guide to Engine Hanging. Using their instructions I just hung my engine in half an hour all by myself. They actually advise against the solo thing, but I did have people in the house if I needed them. It's kinda spooky when something goes this smoothly.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 07-13-2007, 02:01 PM
pierre smith's Avatar
Default Big rubber-little rubber
Great Steve,
You did put the small hard rubber mounts on the lower forward side and the upper rear didn't you? They're easy to get wrong.
Regards,
Pierre
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 07-13-2007, 02:33 PM
RBD's Avatar
RBD RBD is offline
What is this Tampa Builders' Group and where can I find out more? I'm still a year or two away from beginning my own project, but I'd love to meet some local RV folks.
Old 07-13-2007, 03:36 PM
Originally Posted by pierre smith
Great Steve,
Regards,
Pierre
What rubber mounts?? Just kidding . You're right, the arrangement is a bit confusing but I triple checked it and all is correct. Thanks.
Steve Zicree
Old 07-13-2007, 04:12 PM
Ironflight's Avatar
VAF Moderator / Line Boy
When I did mine,I very carefully put all the rubber pieces in the right spot and installed everything before my helpers left. Then I discovered that the upper and lower bolts were slightly different lengths and - you guessed it - I had them reversed....fortunately, changing them by myself was not a big deal, as I had one extra bolt the right length to hold things together as I played "Chinese puzzle squares..."
So Steve....goit the bolts in the right spot?
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
