<<1) Appliying additional fiberglass
- Can it be applied over epoxy/micro or epoxy/flox (I don't think so?)>>
Epoxy/micro: no if structural, yes if not structural or if merely used as a small core filet joining two right angle structural parts, epoxy/flox: yes for anything.
<<If applying over a "finished" piece of fiberglass, how should it be prepared? Epoxy surface scuffed down to glass layer?>>
Yes, 36 to 80 grit. Don't cut into the glass; the glass skin on a honeycomb core is pretty thin. Kill all signs of gloss and you're good to go.
I dunno about bonding to gel coat. I'd probably remove it.
<<2) Priming/painting fiberglass
- Must Smooth Prime or equivalent be applied first?>>
Gotta do something to fill the pinholes and scratches. Best is a pure epoxy wipe, squeegee it on, squeegee off all you can get, repeat in a few hours when the first coat tacks up. Harder to sand than Smooth Prime, K36 or whatever, but I'm finding it less overall work than sanding the SM and K36 multiple times following multiple coats. I've been experimenting with Clear Coat from System Three, a water-viscosity epoxy. The experiment parts had zero pinholes when I sprayed the first primer coat. Yessss!
<<Lightly scuff surface of epoxy?>>
Always before applying anything else. Kill the gloss.
Dan Horton
RV-8 SS
Barrett IO-390
