Old 07-13-2007, 10:30 AM
Brambo Brambo is offline
Default Tapered Reamer
After reading about problems with the nose gear becoming loose in the engine mount socket, I decided to try using a taper pin. Following the instructions of the Jim Ellis artical on installing a taper pin http://www.matronics.com/wiki/index.php/Nose_Gear_Strut , I find that the taper reamer doen't seem to be working. I first started using a ratchet, turning slowly and using plenting of cutting oil. Then I tried a electric drill at slow speed. Still no apparent progress. Is there a trick to this or is it just going to take a LONG time? If someone out there has used these taper reamers before, any suggestions would be welcome.
Bill Rambo
RV-7A
Old 07-13-2007, 10:37 AM
Brantel's Avatar
Brantel Brantel is offline
Are'nt these legs tempered? If so, it may be hard if not imposible to do this.... If not, it should work, just go slow and clean the reamer often. Make sure you are turning the reamer the correct direction.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 07-13-2007, 12:09 PM
tonyjohnson tonyjohnson is offline
Default reamer
Jim Ellis says that it is not difficult. You might want to send him a private message or wait for him to respond here when he sees this thread. Perhaps he has some hints.
Tony Johnson
RV8A "Badboy" N12TJ
Treasure Island Florida
Old 07-13-2007, 12:20 PM
DanH's Avatar
DanH DanH is offline
Might need a carbide reamer.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-13-2007, 12:26 PM
sandifer sandifer is offline
Most taper reamers are designed to be used by hand. Use a good two bar tap wrench and do it by hand.
I used a Brown and Sharpe taper on my RV-3 gear legs and trashed one reamer by not applying enough pressure initially. If you don't start it cutting right away, you'll dull it in an instant and it will never cut. Could be the problem you're encountering. I tried again with a new reamer and it worked perfectly. Should not take long at all. After drilling the holes, reaming was the easy part.
Old 07-13-2007, 12:59 PM
Darn, that sounds like what might be the problem. I guess I'll try a new reamer.
Old 07-13-2007, 01:03 PM
mdoyle mdoyle is offline
Most reamers have straight flutes, so they do not self feed at all. It takes a lot of pressure to get them to cut. If you were able to drill using the S size drill, you should be able to ream it without a problem. Remember, a taper reamer is cutting the entire depth of the hole, when you are getting close to being finished, unlike a drill bit that cuts mainly at the end.
Mike Doyle
RV-12
RV-9A, Under Construction
Xenia, OH 45385
Old 07-13-2007, 03:51 PM
Jim Ellis's Avatar
Jim Ellis Jim Ellis is offline
Bill,
When you ream the hole for the pin I found that the reamer would often turn but not cut. You must hold firm inward pressure on the reamer while you're turning for it to cut. It seems, if you ease up on it, debris gets under the cutting flutes and prevents good contact with the stock. When this happens remove the reamer wipe it clean with a lightly oiled rag and clean the hole...then try again. Firm inward pressure and a slow steady turn seems to work best. You can "feel" the reamer cutting when everything is just right. Do not try to use a power drill...it just spins the reamer in the hole.
Sometimes a small burr will form on the edges of the reamer flutes. Use a small flat stone on the inside edge of the flutes to remove them if they occur.
Also don't use too much cutting oil...this seems to cause the reamer to loose it's "bite" on the metal.
Good Luck!
Jim Ellis
RV-7A, N23VC, Slider, Garmin G3X Touch Panel,
Barrett Precision Engines Superior XPIO-360,
Dual P-Mags, Airflow Performance FM200A,
Classic Aero Designs Interior,
GLO Custom Aircraft Paint,
Flying
RV-9A N155T, Sold
Old 07-13-2007, 04:36 PM
Is there someplace that describes the proper way to use reamers? I hate to admit it -- now -- but I have no clue how they're used.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 07-13-2007, 05:14 PM
ctbecker ctbecker is offline
I like the concept of a tapered hole that can continually be tightened, but I've given up on a source for the pins. Even AS wont stock them because ther is not enough demand. Others have $75 minimum orders.
Charlie Becker
N464CB. RV8A(es)
Certificate Issued
