Avi8tor50:
I'll check my photos at home, but Im not sure that I have any photos other than from after I already did my fiberglass layups.
Here is a little more info:
I think this is the foam I used:
http://www.aircraftspruce.com/catalo.../styrofoam.php
It should be able to be shaped by sanding without much difficulty. If not, its the wrong stuff.
I temporarily glued sand paper to the skin in the problem area using spray adhesive. Then I took an oversized chunk of the foam and rubbed it against the sand paper on the skin in short, fore and aft/up and down strokes until the shape of the foam perfectly matched the curve of the skin. Remove the sandpaper and adhesive from the skin, then scuff the skin area with 60 grit. Then put a thick layer of epoxy resin on the shaped side of the foam block to seal it and permanantly attach it to the skin. Seal up the finished foam wedge with resin and you are ready to do your fiberglas layups, which will now be fully supported and perfectly shaped.
One detail: A small sliver of the foam wedge you created will be exposed between the windscreen and the interior glare shield, and may later be visible from the outside, or perhaps from the insided if one were to peek over the top of the glare shield (you will see what I mean when you are test-fitting and forming the foam block). Since the blue foam looks out of place and ugly there, I waited until I had the foam block perfectly shaped, and before attaching it to the skin, I painted the small area that will remain exposed black to match the top of the glare shield. You must seal the area to be painted with resin before you paint it or the paint will EAT the foam that you just shaped to perfection (ask me how I know this).
This really isnt too hard, nor does it take all that long if you dont count the time for the resin to dry. Dont be afraid to do a quick and dirty trial run (without epoxy) with some cheapo floral foam to get an idea of how it will go. I went from "very concerned" about my windscreen fit to "pleased", and the subsequent fiberglass layups were shaped the best where underlayed by the foam. I wouldnt terminate the layups on the foam - continue them so they overlap the skin below the foam to provide a measure of protection.
E-mail direct with more questions if needed
regards
erich
