Old 07-11-2007, 03:51 PM
Wayne's Avatar
Wayne Wayne is offline
Default Indicated RPM out by 300 - ideas?
Went to airport early this AM to get my prop balanced. No adjustment needed as it was within spec BUT the indicated RPM on IK2000 was out by 300 RPM (higher!) vs the prop balancer computer AND the seperate RPM strobe.
I am running the Light Speed II with the hall senors on the fly wheel and the IK2000 is taking the readings off that.
I would apprecaite input from anybody else that has had similar experiences.
Wayne
RV 7 "eh?" C-GOYA - 450 hrs
RV 10 C-GOOH - 475 hrs
R44 225 hrs
Aerostar 601P 130 hrs
grounded by stroke Sept 3/07 - and back flying Feb 2010. Don"t ever take flying for granted !
Old 07-11-2007, 04:24 PM
Jim Ellis's Avatar
Jim Ellis Jim Ellis is offline
Hi Wayne,
I have I-K Technologies AIM-2 that reads 200-300 RPM higher than either the mechanical tach or the optical tach (which pretty much match each other). In my case the AIM-2 is getting its signal from my left P-Mag at 2 pulses per revolution. I havn't talked to Ralph at I-K Technologies about this so I don't know if he has a way of correcting the error. You might give him a call and see what he has to say.
Let me know if you find a way to correct the problem.
Jim Ellis
RV-7A, N23VC, Slider, Garmin G3X Touch Panel,
Barrett Precision Engines Superior XPIO-360,
Dual P-Mags, Airflow Performance FM200A,
Classic Aero Designs Interior,
GLO Custom Aircraft Paint,
Flying
RV-9A N155T, Sold
Old 07-11-2007, 07:39 PM
Vern's Avatar
Vern Vern is offline
Default RPM error:IK-2000
I've had errors on my IK-2000 tach reading since it was new. It is accurate until about 2200 rpm but above that it begins to get off. A few years ago Ralph worked with me some and I tried a different tach generator. It was not a corrective action so I went back to the original tach drive. He promised more help but it has not been forthcoming.
I put a EI tach in my RV-6A and use it for my primary tach now. (EI=Electronics International)- A wonderful company and great products!
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
