Old 07-09-2007, 01:50 PM
prkaye prkaye is offline
Default CorrosionX
I don't want to get flamed for asking this... forgive me if this is a brutal idea.
I have only been priming my mating surfaces (rattle-can self-etching primer) and places where I drill or cut and the alcad gets broken. I do NOT want to get into a debate now about this decision... it's been made.
Anyway, now I'm looking at my wings (bottom skins still off) and wondering to myself if it would be prudent to spray a wee bit of that CorrosionX stuff in there before closing them up. A light misting over the insides of the skins.
Is there any reason why this would be a BAD idea? Concerns:
1) could the stuff seep out through joints and get under the final paint-job, causing problems?
2) how heavy is the stuff?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 07-09-2007, 02:28 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Not before paint
Based on having my 150 fogged a few times, I think there is an excellent chance it will bleed out as a normal part of the process. I'd wait until after paint.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 07-09-2007, 02:50 PM
JHines JHines is offline
I had a 172 done, I second that it will definitely continue to weep out for a while after application. I've heard some paint shops won't paint a plane within several months after CorrosionX.
The Mfr. states 7.0 lbs./gal and shows test results for a coating 0.15 mils thick. My crude calculations show that would be about 0.006 lbs. per sq. ft. covered at that thickness.
Old 07-09-2007, 11:43 PM
rv72004 rv72004 is offline
Wipe down the surfaces with a oiled corrosion x rag. This will apply the minimum coating and will not seep through if applied correctly.
Just a idea
EJ
RV7 flying
xp360, CS, All Glass cockpit
