Old 07-09-2007, 12:42 PM
lcnmrv8r's Avatar
lcnmrv8r lcnmrv8r is offline
Default weight difference O-320 vs O-360
Can anyone give me the weight difference between the O-320 and the O-360??
Seth
Las Cruces, NM
Old 07-09-2007, 01:12 PM
cjensen's Avatar
cjensen cjensen is offline
Here's a page with all kinds of info for ya! There are LOTS of different 320's and 360's, but generally it seems the weight difference is about 10lbs.
Engine info
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 07-09-2007, 01:27 PM
FredMagare FredMagare is offline
Here's a good link where you can download information on the different engine types:
http://www.lycoming.com/engines/non-certified/index.jsp
Click on an engine type and you'll be able to download a .PDF spec sheet
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
RV-9A Firewall Forward
[Engine purchased]
Old 07-09-2007, 06:24 PM
ron voss ron voss is offline
Default O-320 HP
I am about to fly my RV-6 with an angle valve O-320 that should produce around 180 horsepower. The cylinders are from a GO-480. It also has E-mag/P-mag and Vetterman crossover exhaust. Weather and my schedule should be good later this week to get the firrst flight in. The Catto 3 blade was pitched to assume 170 HP, but I expect a little more. There was an STC for this mod with 4 levels; cylinders only, cylinders and rods, crank too, and I forget the other level. Carb horsepower was supposed to be 178 and fuel injected was 182 I think. These cylinders are probably quite a bit heavier, but my empty weight was still only 1015 (painted, with wheel pants, but no gear leg or intersection fairings).
Ron Voss
RV-6 N642R Finally Finished!
