Lycoming TIO 540 not devloping max power HELP!
Hi There
I am new to this forum, i came across here by chance looking for solutions which i having been going through for a while.if any on could advise me to solve this problem. The brief history as follows :-
This is Lycoming TIO 540 engine is not developing power when full throttle is forwarded ie. 2575 rpm, another thing noticed the fuel flow is low at 40
psi, it does not reach to the top of the gauge on full throttle but when the mixture control is leaned back the engine RPM increases to the desired RPM so for this power problem i have interchanged each and every accessory from the other good engine, even took out the cylinders to check the cam lobs for ware, changed fuel injection servo, fuel pump, turbocharger, waste gate,density controller, magneto re timed (internally & externally), governor, and also the prop, pretty much every thing still i am going through the same problem .
I WOULD BE GREAT FULL IF ANY ONE CAN HELP WITH SUGGESTIONS
Regards
