07-09-2007, 08:35 AM
conduit and proseal
I have the flexible conduit for wiring from Vans. I drilled the holes in my wing ribs as per Vans instructions. They say to gob some proseal around the edges of these holes to prevent them from cutting through the conduit. One thing is not clear to me... is the idea to gob the proseal around the holes and then let it dry before pushing the conduit through? Or to push the conduit through while the proseal is still wet (messy job??) so that it dries in contact with the conduit?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
07-09-2007, 08:54 AM
Push through, and gob it on
Hi Phil,
We pushed it through, then gobbed it on. You just want to prevent the vibrations from having the rib cut through the conduit.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
07-09-2007, 09:17 AM
Phil:
You might try RTV; it's easier to work with. Put a bead on both sides of the rib around the conduit after it's installed.
Jekyll
07-09-2007, 09:19 AM
Ok thanks. And how much conduit did you guys leave sticking out of the end ribs (inboard and outboard)?
Phil
RV9A (SB)
Ottawa, Canada
07-09-2007, 10:42 AM
I left a foot on the root and about 6" on the tip. Can be trimmed back later if needed.
07-09-2007, 12:27 PM
I try to avoid RTV in permanet installations, it's not really great for aluminum, and it comes off after awhile. I'd stick with proseal.
Originally Posted by Jekyll
Phil:
Jekyll
RV4 wing in Jig @ KPOC
RV7 emp built
07-09-2007, 01:15 PM
Aviation grade RTV
Non acidic RTV is fine on aluminum. Proseal is great stuff but probably overkill for the conduit. I used high quality RTV for the conduit and also for snap bushing plus many other places where I don't really need the strength of proseal.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
07-09-2007, 02:15 PM
what about silicone adhesive?
How about silicone adhesive? I used a few dollops of it to adhere a heavy telescope mirror to a metal mirror mount a number of years ago and it is still strong and flexible. I suppose Van's recommends Proseal (or its equivalent) as that is what they have handy.
I have gone to Home Depot and asked for RTV and I got this wierd look. I thought everyone knew what RTV was, but they don't seem to have it.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
07-10-2007, 08:26 AM
They can't even spell RTV
I bought a tube of silcone especially made for aluminum sealing/bonding at HD to use in my elevator TE's. Be a guy and don't ask for help. Just find it yourself!
Bill Grant, A&P
8KCAB, M20G
RV-4: Fuselage controls
07-10-2007, 09:00 AM
......I thought everyone knew what RTV was.....
Quick sports fans.....without looking it up (VAF honor system), who will be the first to tell us what RTV stands for?
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
