Without a picture, it is hard to tell, but it sounds like you have fisheyes, rather than pinholes.
A fisheye is where oil, silicone, or some other substance contaminated the surface, causing problems with the paint's surface tension and causing a semi-transparent circle in the paint. A pinhole is a tiny little sub-surface bubble.
There are fisheye eliminators that can be added to paint, but the best solution is to make sure your surfaces are very, very clean.
Did you wipe down the surfaces with FinalKleen (sp?) or some similar solvent based oil and wax remover before shooting the finish coat? Any auto body supply store will carry this type product.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
